myersmobilemarine
I am trying to figure out how to remove the shift shaft. I need to replace the lower unit seals around the drive shaft. The diagram I have shows removing two pins.... that ain't happening with this model. Does the prop shaft clutch dog assembly have to be removed to release the shift shaft. could use some help.
