myrtlebeach
I have been studying the factory service manual and cannot find the answer to my problem. I am hoping someone here can help. I have a 2001 BF130. Recently purchased and never been fired up yet. I have wired it up and started running diagnostics. Changed plugs, oil, filter. Checked compression etc. When I try to start it, wont fire. Checked plug wires with timing light, OK, get spark. Pull plugs, no gas getting to cylinders. OK, install new HP fuel pump. Check, comes on for two seconds as it should. Check pressure in lines. good. Injectors aren't firing. OK. Computer problem. Short connector to check MIL functions. MIL light comes on and does not blink. OK, bad computer. Get new one installed. Run MIL check again. MIL light comes on and stays on but, this time it is accompanied by a constant alarm which is new. So my question is: what does it mean if the computer shorting wire is inserted, turn switch on, all 4 lights come on for 2 seconds, fuel pump runs 2 seconds, temp and green oil light go out, ALT and MIL light stay lit. do not get 2 beeps but instead have constant alarm? Any help greatly appreciated.
