BF130 Three way joint
BStob
I cannot find a three way joint for honda BF130 - I believe 2001. The part number is 19269-ZW5-000 (or -010) which has two stems the same size and the third stem a smaller diameter - Does anyone know how I can get this part- new or used? Seems like honda has discontinued the part
Hi,
are you sure about those part numbers?
I plugged both versions...
19265-zw5- (000 and 010)
into yumbo-jp.com and the message was the numbers can't be found.
Usually, that Japanese parts site will say if a part has been discontinued if it's a good number for a " no longer available" part.
Sorry, that's all I have.
Good luck.
Could you use a "universal" type in that application? I'm assuming it's a water tube T but you didn't say.
Measure the three nipples if you still have the old one and see if the one in the link below might do ya.
Good luck.
OH!..... Yeah!!!
Thanks for pointing that out Bob and for posting the attachment too!
Goodonya sir!
It's got a price listed with it so that means it usually IS available from them.
But shipping cost might still make the universal one the more attractive solution.
ALTHOUGH...
...it's listed for fuel so I don't know if the Dorman vacuum "T" would hold up to gasoline. Conundrum.
BStob, sorry for my mistake.
SHEESH! IT'S MISTAKE day for me!!
the price listing I referred to was for the 19269-ZW5-010 and NOT for the
19269-ZW5-000.
So, it's probably NOT available through them.
All you can do then is to request a quote as Bob has already suggested.
Again, apologies.
On a positive note though, I'm sure that there MUST be a BRASS 3 way connector that you might substitute if you can't find the original.
A good hardware store will typically have some of those types of brass fittings in stock and may be able to special order one from their supplier if not. Just make sure that you give them accurate measurements.
Good luck.
