Hello,
My 2002 BF130a3 has a rev limiting or running problem and wont rev over 2000. I suspect something to do with the oil pressure rev limiter at 1800rpm.
I need some advice on how to troubleshoot.
According to the user manual:
The green oil pressure light should come on for 2 seconds when the key is turned on, but it does not come on.
The green light does not come on at all when the engine is running either, but it should be on when the engine is running if the oil pressure is good..
Again, the engine will not rev over about 2000rpm.
Maybe the ECU is bad and not controlling the light properly and throwing it into rev limited mode. I would like to test the light first to make sure the bulb is good and the wiring is good.
This is a beginner question but how can I test the green light and wiring without cutting the insulation and damaging the weatherproof sealing? The light pod on the dash is sealed. Also concerned I could damage the ECU if i test improperly.
Are there any other suggestions on how to figure out the problem?
