speedboatsteve
Hello all,
I'm stuck and really need your help.
Not sure how yet but somehow I'm getting water in the gearbox despite having replaced the seals on the shift rod, under the water pump and prop shaft (Without removing bearing carrier
) and despite a 10 PSI pressure and vacuum test being ok, my gear oil still has water in it so I think it best I strip the gearbox for inspection.
The gearbox is off and sat on my bench, I've remove the water pump and shift rod plus the 2 bolts holding in the bearing carrier but it wouldn't budge at all so I rigged up a puller however even this doesn't seem to be working. Its now been sat with the puller on for 24hrs and covered in WD40 but it still wont move.
Is this normal or have I missed something?
