I-Underdog
Hello Everyone,
I have a weird one.. 2002 BF115, Is leaking oil on the port side. The oil is collecting, clinging, on the bottom of the trim tilt relay. it drips down into the gully, runs back to the center drain hole at back and runs down the lower unit. I cleaned the entire area with Lectra-motive and wiped it all dry last night. Then ran it on muffs for 15 minutes. No leaks observed.
This afternoon, the oil has returned, the highest point I can find is the bottom of the TT Relay. Also a little oily on the left, on the trim tilt wires.
Is there anything behind or above the Relay or the ECM box that has a plug or a seal ? I inspected with a flashlight for a long long time, up front. The shift shaft seal is clean and dry... The little drain pipe (up front) for the flywheel case looks clean and dry. I took the timing belt cover off and inspected the top, the top is clean and dry, I don't see anything dripping down. I am scratching my head. Anybody have any advice or ideas ?
Thanks,
Chris
Thanks,
Chris
