I bought a 1983 Honda bf100 that is in immaculate condition and started easily. I took it out the first day and I couldn't get the fuel line to hold prime so it kept dying but worked fine. The next time out after fixing the fuel line, the motor was peeing just a little bit but I didn't think much of it as it was a new engine to me and didn't know what to expect on the amount. I went out for a few minutes going through different rooms and noticed there was almost no water peeing out now. I shut the engine off and poked a wired through the drain hose tube and into the water channel hole. I couldn't get it started for about 10 mins but when it did it was peeing again. I took off further out in the lake and noticed the flow of water was very inconsistent. After a few more minutes of running it I realized that it probably wasn't working right. I took off and went back in. When I got back near the dock, the engine died and steam was coming out of the cowl. After getting it home, I checked the thermostat and it was completely corroded and not operable. I replaced the thermostat and started it up and it ran and pushed more water out at idle than what I have seen since I bought it and matches what I have seen from some youtube videos of others same engine.
I then checked the oil and realized that the oil is milky and the level was low. There is also oil that is down under the engine as well as some that drained on the ground feom the drain grommet hole in the back left of the engine. I know in cars, milky oil is usually a head gasket but is that the same thing on these? Is there a possibility that I toasted this engine? I am about to tear the head off but wanted to ask what else to look for and watch out for so don't miss something along the way.
Any help would be appreciated as I bought this to hope to be able to go out and enjoy the boat with the family this summer but it has backfired so far.
Thanks!
Thanks!
