I just measured the original sensor ; at room temperature = 2.5k ohm after heating up sensor with heat gun reading is .4k ohm so yes resistance drops as sensor heats upI think the sensor is probably an NTC that loses resistance as it heats up and provides a ground to "turn on" the engine protection feature causing the power reduction and engine stall. Disconnecting the wire takes ground away and disables engine protection.
But...I think it's possible that wire could be very slightly touching ground someplace where the insulation is chafed or damaged and is causing the engine protection to be activated.
Just a theory though.
