Hoping someone can helps me out with this problem.
Motor starts right up, no problem at idle but under load it will run for a few minutes then die slowly over a few seconds.
It will start right up again and repeat the same thing with out priming so I believe that rules out fuel, bulb always is stiff and priming will not keep it from dying. Oil pressure light is always on,
The tell tale has a stream and when I run it with the thermostat pulled and the cover open there is flow just not sure if it’s enough if this is an overheating issue possibly impeller?
Motor is a pain to remove from the rib so I would like to be somewhat sure of possible causes
