huntermanryan
Hi all, new to this forum and I'm kind of at my wits end on this one, looking for some assistance.
I have a 2013 BF225. After idling for a few minutes at the ramp, and passed no wake zone, I can jump up on a plane and after about 15-20 seconds it will SOMETIMES show an alarm on the Garmin indicator PGM-FI Engine Over Temperature. This puts The motor briefly into limp mode until I bring boat down to an Idle. As soon as I idle down, limp mode clears up, alarm goes away, and the issue likely won't arise again on that trip. The motor is not overheating, not even close. The temp gauge shows between 170-200 depending on RPM. Here's what I have done so far:
-Replaced both t-stats
-Replaced Temp sensors on exhaust manifold
-Replaced impeller
-Inspected manifolds with borescope for corrosion or blockages with borescope (very clean, no significant corrosion)
-With motor running at idle, shot the manifolds with IR temp meter, nothing abnormal.
-Ran a descaler treatment through the motor just in case, no changes.
Most of these parts are maintenance items anyhow, so I didn't mind replacing them for the sale of good measure, but this intermittent alarm keeps going, and is not repeatable on command if you will. Is it possible to that there is something other than the temperature system giving me this error, like possibly a coil occasionally going out under load? Or maybe an O2 sensor? I really don't want to keep throwing money at the wrong problem. Any help or suggestions are appreciated.
I'm have attached an image I took of the error message that comes up, but again, it cleared itself as soon as I come to idle.
-Replaced impeller
