Lucky Catch
I have twin BF225s. One of the motors keeps stalling. It’s like it is running out of fuel. Usually happens over 2000 rpm and seems like it happens when “going over a bump” wave wake etc. I have changed all filters including the high pressure filter. Also replaced the primer bulb and associated fuel line. I did notice the low pressure fuel filter is not “full”. However the other motor is the same. I have ruled out any issues with the tank and lines from the tank as I have run the motor on the other fuel tank and had the same problem.
Unless anyone has any other ideas, my next step is to tear the VST off, clean it, replace the needle and seat on the float in the VST
Thanks in advance.
Thanks in advance.
