I have a pair of 2003 BF200's and see a difference of about 300-400 rpms between the port and stbd at WOT. They have the same props on them but the port has a newer gear case. I am not aware of any changes in the ratios from '03 to '12. The gear case was changed before I bought the boat.
Both engines have all new fuel filters, as well as the racors on the boat. I have also replaced the plugs, O2 sensors, cleaned the IAC's,checked the map's and made sure the cables are allowing both engines to open fully.
Both engines seem to be slightly erratic at idle but nothing serious. I never had 4 strokes before so am not sure how steady or smooth they should be. They run perfectly smooth at all other rpms and have no noticeable issues with power or performance. Both props have just been balanced and cupped. The engines have just over 900 hrs on them. Should I be looking into having the injectors checked/cleaned? Could they be causing the rpm issue,idle roughness, and any fuel economy issues? I do notice the port engine does burn more fuel than the stbd at the same rpm. I can never get the port to equal or use less fuel than the stb unless I greatly drop the rpm. The difference is about 1-2gph on average.
