Hi guys, first post here.
I have a catamaran with a pair of BF 20s, ultra long shaft with high thrust props.
A few days back, the port motor, which had been running perfectly, just stopped. I checked fuel which was OK, drained the bowl on the fuel filter, no water, but no restart either. I let it cool for a while but still dead. It turns over fine, but doesn't fire.
So we motored home on one engine, and I started testing. Pretty soon discovered no spark.
SSo since I had a known running engine, I decided to do some parts swapping to try to determine what was wrong. So far I've replaced: the entire ignition system, rotor, stator, pulse generator, CDI box, coil, leads and plugs. I've also replaced the overheat cut out switch and the oil pressure switch. I even swapped carburettors. The earthing on the coil seemed suspect, so I've wired in new earthing for the coil and CDI unit.
I've also swapped over the ignition switch and even the alarm buzzers. There's no MOB kill switch.
I have also checked compression which seems OK too. It's still dead, just does not fire.
And I'm out of ideas. Anyone have any suggestions?
