Problems started late last fall. Engine stalled during cruise and wouldn't start. Cleaned the carburetor, changed rge spark plugs and it worked well for 15 minutes and stalled, wouldn't start again.
Next spring I started a closer cleaning/inspection of the carburetor. Reassembled and could only get it running by spraying gas into the carb. Eventually, took the carb to the local Honda dealer for a professional cleaning and inspection. Still wouldn't run
Emptied the fuel chamber; fuel lines, changed fuel filter, spark plugs but still needed gas sprayed into the carb continously for it to start and continue running
Finally noticed something looked weird in the bottom if my tank and realized there was about 30% water in my fuel!!
After finally emptying all the fuel from the tank, hoses, fuel filter, fuel chamber I managed to get it started(after about 20 pulls) and it ran perfectly once started .
Only problem is that it will no longer start with the choke and it takes upwards of thirty pulls to get it started. Even after it just fires up, if I try to open the choke a tiny bit the engine starts to stumble and stall.
So here's my three problems.:
1. Very hard to start when cold.
2. Using the choke only makes it worse.
3. Spark plugs have a whitish electrode(curved metal arm) which suggests that it is running lean and maybe fuel starved. HOWEVER; once started, it runs well, all day and hot starts always on first pull.
The motor was bought in 2011 so has about 9 seasons of use for the fuel hose and primer bulb(never been changed). The bulb pumps firm but never completely fills rhe small fuel filter before the carburetor Is this normal? I thought it should be completely full of fuel to prevent any priming problems...??? The hose and primer bulb looks fine but could this cause the hard cold starting and lean running???
Please do offer an advice or experience in this matter. It will be most appreciated!
