adamfishdaniel
"I have a Honda BF 15A that wi
"I have a Honda BF 15A that will only run at about ¾ power until it is warmed up then it will surge a bit and then jumps up on plane. The strange thing is I have taken it out 8 times and it gets up on plain in the same spot (about 10 min of run time) every time. If you shut it off and start it immediately it will run perfectly again. If it cools down for an hour or more you go though the same thing again. Both cylinders have spark, I pulled and cleaned the carb (it was spotless), new spark plugs, the fuel pump is strong, tested the trigger looks good, the kill switch checked out, the gas is new, thermostat is within spec, no crap in the fuel filter and throttle linkage is good. I did the test for the CDI unit that was in my book and some of the pins were not within spec but I was told you can’t test those things."
