"Have a late model BF15D , it
"Have a late model BF15D , it would not idle after the enrichment valve closed so we removed the carb. and cleaned out the circuit to the idle screw(it was blocked in the small tube that runs vertically)also checked the main jet, cleaned the inside of the bowl,checked the float valve:all looked good.Reinstalled, started engine, runs ok during enrichment, idles OK after enrichment ends is having very hard time reving up, will eventually run at wide open throttle. Noticed the accel pump? plunger never moves, is it suppose to?
Have done the online thing to access diagrams. Any Ideas?"
