WilliamMiles
Honda 60 will not charge the battery. When running, I disconnect the battery and it shuts off. What issue do I have? And how can I fix it?
2021 Honda 60HPDoes it drain the battery while it's just sitting and not running?
Or, does the battery go dead only while it's running?
What year is the outboard?
Thank you, I will check the fusesThere are 4 fuses listed....
Items 3, 11, 12, and 13 in the parts page link below.
I'm not positive but I believe that the 40 amp fuse (item 3) is the alternator fuse that feeds the rectifier/regulator.
If that fuse is blown and there's no charging, the engine ignition and fuel systems will be running strictly on the battery and will discharge it pretty quickly.
If the fuse is good then you will likely want to see if there is power getting to the rectifier assembly on the white wire.
Since I don't have the shop manual or a wiring diagram, I'm afraid that's as far as I can help you troubleshoot this from here.
Good luck.
