jldsomething
can anyone tell me how to tell the difference if my switchbox is bad or trigger?
i have no spark at all three plugs
its not coil i have changed that.
im getting power to switch box
wires are all fine i have checked.
its a 65 hp mercury year is 73-75 not sure. serial number starts with a 405.
i have tested all the manual will tell me and am at a loss i do not have dva tester only a automotive ohm tester.
most things i have read point to switch box because none of the 3 plugs are firing at all.
also the problem is intermediate it was starting and running then took a lake and wouldn't start back up then brought it home and it would start and went out the next day and it would not start.
i have tested switch box while trying to start and one white wire as hot as crankin over but no power going to the coil or other wire on the distributor.
