It is back firing all the time weather in neutral or under load.Does it backfire from exhaust in neutral also or only in gear underway? Also are you sure it backfire or spitback thru carbs?
It back fires from exhaust not the carbsDoes it backfire from exhaust in neutral also or only in gear underway? Also are you sure it backfire or spitback thru carbs?
The firing order was wrong and my mechanic couldn't be right one. Now engine is runningbbetter then it ever had.Make sure firing order is correct as there is 2 different firing orders for 3 cylinders
