neversummer
I have a 2007 Honda 50 4-stroke.
I usually flush it with fresh water on the muffs in the driveway.
Sometimes the pee stream is not strong on the muffs and I need to squeeze the cups together to create enough pressure for it to pee well. This usually happens when the motor is cold and goes away once it is up to temperature.
My question is: Does an impeller get damaged because no water is running through the motor (ie, not peeing yet) or because there is no water flowing against the inlet vents (ie, if you were to run it dry with no hose)?
Should I be worried about those moments when my hose is on and water is running against the inlet vents (but not strong enough to make it pee with strong flow) or is the impeller totally fine because it is being "bathed" in water?
Thanks.
Thanks.
