Well, I've been working putting together a 25 Evinrude for my 16 footer. What appears to be a 91 power head attached to a 92 to 94 body.
Its running but sputters, spits and feels like like I'm dragging an anchor. I thought it might be the timing but after researching it seems that thats set at the factory and never needs to be adjusted.
When I swapped the head over I did it as a complete unit, meaning that all the electronics, carb, cables were swapped with it.
To trouble shoot , what I have done is
1) cleaned every electrical contact , added dielectrical grease
2) made sure all grounds were good
3) pulled fly wheel and checked key and cleaned under it
4) changed plugs
5) swapped out both coils and plug wires (with some that I had as spares)
6) swapped out carbs ( seemed to run a bit richer, more smoke but still sputtered)
7) Took bowl off original carb, soaked it in sea foam and blew it out with carb cleaner. have not done a total re-build on it yet.
8) compression is 110 on top and 108 on bottom cylinder
9) no leaks or clogs in fuel lines
10) fresh 98 oct gas mixed 30 to 1 with 8 ozs. of sea foam added
11) ran it at night to look for any arcing , didn't see any.
Is there anything I might have missed?
4) changed plugs
