Bit of detective work here.
I have a curiosity that had bugged me about my 99 bf130 since i bought it and the boat used. I *know* this motor is an affected serial number for the block casting.
I know zero about the history of the motor.
The motor also had white pen markings next to each plug on the valve cover, 145, 150,145, then a yellow mark. no number. (like a tech was writing compression numbers are something, just white , yellow ink).
here's the thing...those numbers are not right as the manual states 199-228 & 300 psi. Now when I test compression it is dead on, i mean dead on 215, 215, 215, 215 maybe could be a variance of 5lbs due to my
my gauge but i tested it also against my air compressor and it's not more than 5lbs off through the range. The boat hour gauge had 275 hours but you know those don't mean anything. So obviously these numbers are excellent.
No markings under the hood of if the block replacement had been done.
Just curious what a tech may think, like if there's a convention. The readings are so good and the numbers odd ALONG with the yellow mark on the bottom one (#4 iirc) it almost makes me wonder if a powerhead could have been done in the past and the original valve cover put back on. But this just may be wishful thinking =) but i'm not worried about the motor runs. great. Just curious what you guys make of that
