I have a 2003 Honda 225 on my bay boat. I store the boat in a side yard under a cover. I had not run the boat in 3 weeks, so I ran it this morning on a hose to warm up the motor & move some oil around. When running there are various small holes built into the lower unit where water escapes by design...these holes are about the diameter of a pencil, and there are three or four on each side of the lower unit. So water is coming out of those holes, out of the prop, and out of the pee hole in the upper part of the motor as normal. Suddenly, ants start running out of the holes on the port side of the lower unit, some of them carrying eggs! I have an ant nest in my lower unit!
There were dozens (not hundreds) of ants coming out. They looked like carpenter ants, not a dirt building ant like fire ants. The motor ran fine at idle on a hose. I tried to wash them out as best I could, but I have no confidence I got them, or any nest debris, out of the lower unit.
I figured I would take the boat out tomorrow to run it and wash away any ants...but now I'm wondering if ants or nest debris could get sucked into the powerhead water passages somehow and clog them. Is this a possibility?
