vikingtime
I went to turn over the engines for the first time this season. The port side started up good. The starboard was hydro-locked with antifreeze in five cylinders. There was lots of antifreeze.
The starboard ran fine when I winterized it in the fall.
I pulled both heads last night thinking it was head gaskets but the gaskets looked good. I'm sending the heads out for testing today.
I did do lots of work on BOTH engines this spring and now I'm starting to think I must have caused this problem.
Elbows/Risers
Boiled HEX
New U coolers
New Raw water pump
All new hoses
New Thermostat
New plugs
When I replaced the risers and elbows - I used the gasket diagram recommended on this site and it appears that I followed it (I can see the tabs of the gaskets -they look correct). I'm wondering if I could have put the "water outlet adapters" p/n 97295 -that go between the manifolds and risers on backwards?
I added 4 gallons of antifreeze to the motor and before I even cranked it, the antifreeze seemed to have drained into the cylinders.
I'm baffled and hoping you can offer some advice.
Thanks!
Scott
Elbows/Risers
Boiled HEX
New U coolers
New Raw water pump
All new hoses
New Thermostat
New plugs
Thanks!
Scott
