NaymzJaymz
Hello again guys. I've been following jgmo's advice about disconnecting the shift shaft on my Honda BF100('82) so I can remove the gearbox for an impeller change. Because of my inexperience, I'm a bit worried about trying to unscrew the shift linkage connector from the top of the shift shaft with the shifting mechanism in the way. As jgmo said, it is a tight sqeeze! The connector will probably come off just by pushing it around with the head of a screwdriver, but how the heck will I get it back on? How can I even begin to get it to start threading back on? The shift shaft is in the lowest position it can go with the connecto still on. It seems it would be better for me to remove the shift lever assembly, but when I unbolt the 2 bolts that hold the horizontal bar in place, the bar will not pull out, even though the whole assembly is now so loose (including the shaft)that it wiggles and moves easily in my fingers. What is holding the shift lever in place now? It don't want to damage it by hitting it. I also wasn't expecting to have to unbolt what looks like some sort of cube shape heat riser of sorts in order to get out the pin with the tiny cotter key that holds the shift shaft connector to the shift linkage. What is this thing for? Should I ever mess with unbolting the shift linkage tensioner, or is that taboo? It seems like this step will be the hardest part of this project once I get past it. Any help, as always will be greatly appreciated! ---James
