I have two almost new 2018 BF150s with just under 100 hours. The engines run great - especially around 4000 rpms. So here's the issue/question. My gauges are the VeeThree NMEA-2000 gauges, but I always use my Simrad Go9. Why does the temperature always report so high (on both V3 and Simrad)? I usually run around 4000 rpms, and the temp is usually around 195. When push things harder, like 4700-5000 rpms it will eventually work it's way up to 215-220. I have gotten the alarm to sound on a couple occasions when making long runs at the higher rpms, and i just turn things off, wait a couple minutes - and I'm good to go. It's only happened like 2 or 3 time. So I just keep things around 4000 rpms (where I've never gotten an alarm).
It seems like other people have run into this issue, and they have had issues with the relief valve. Being such a new engine (and me being the first owner), and not having any overheat alarms (except for the couple of times where I made a long run at higher RPMs), I'm doubtful I have any issue with the relief valve or thermostats or even the impeller.
So what exactly is up with this and the high temp getting sent over NMEA-2000 and to the Simrad? I wish i new what the correct temp was for this be running at (over NMEA)?
Juice
Juice
