Alpha One Stalling Going into Gear
Dockside, if you'll look at page 9 on PDF that bt doc. Posted it says cut if necessary and that's what I was trying to say. THANK YOU
Where did you dig up that dinosaur? I can't remember the last time I saw a support tube cable. Back when I saw one 15+ years ago we knew to just cut them and replace them with a new style cable.
Exactly , you and gosht, wanted to make me look like I don't know what I'm talking about. So next time please hold your mouth before telling me what I need to learn. This 1980's model sea Ray has been garage keeped , cleaner than most 2000 model's, boat came from WI.
There is no way of getting inner cable out aft. without cutting cable. I love talking about how things are fixed. And I try my best to explain what I know.
Evidently you needed to learn.......
I get it all now.
Hey mickey your so fine hey mickey,
This whole topic with regadds to PULLING CABLE OUT
Was about the inner core.
Because you missunderstood the conversation went sideways
everyone who contributes here with the exception of the Ricardo knows all about the OLD style cable and how it mounts to bellhousing.
Hey mickey your so fine hey mickey...
WTF
Kro. It's about pulling inner cable with support tube fool. The book says ✂.
Please tell me how you get inner cable out aft. With crimped support tube. Bet you can't
You dont want to bet me.
I forgotten more than will most likely ever learn....
I fixed, removed many things others said could not be done.
Just sayin'
You are obviously just getting started.
Read and learn.
Offer advice when that advice is accuratE and most of all needed.
you can rest at night knowing I have read all the manuals up to 2002-2004.
Have them all.
Answer question. If you are such a great mechanic, tell me how many pivot gimble rings you've pulled without moving motor ? Simple Question
I have special wrench . that I heated and bent and ground down that will fit on inside of boat on top of steering shaft. Even if I cut out transom holes tap and use plugs . using a air chisel is crap. Even though new nut comes with slots for that way. Doesn't work for me.
I am not going there mikey my man.
Believe me you have a lot of years to catch up.
You just keep doing ya'lls mechanics and I am sure it will all be ok...
Why, you are breaking loose outter transom seal , correct? Why would you do that for gimble ring pivot pin ?
If you break seal on transom outter plate. That's big time
We no longer repair these. We replace them.
Thread title..... "Alpha One Stalling Going into Gear"
We are 51 posts deep, Jack now has a post count of 5,081, and the OP's thread has not only been disrupted many times, it has now become completely derailed.
Thank you Jack and Mickey!
The most important thing that you have forgotten, is how to be polite and how to play nicely!
Something that should have been learned during adolescence.
Just sayin'
Read and learn.
Have them all.
That is good to know.
I'm hopeful that all of us will sleep better tonight!
I know that I will!
Let's all be respectful of one another, even if we strongly disagree.
There is absolutely no need to be childish, to brag, to boast, to be nasty, rude, obnoxious, ill tempered, disruptive, etc.
Let's also understand that this is NOT about post counts. Post Counts only indicate one's participation, and they mean ZERO otherwise. Content is of much more importance.
IMO, If you don't know how a system works or have experience with the actual posted issue, keep your inexperienced opinion to yourself. Most who post their issues on here will not follow a diagnostic procedure to correct their issue. They will look for the quick fix or easiest path and never get the problem resolved. There is not always a simple fix.
A lot of us on this page who help boat owners, are/were successful paid professionals in the Marine Repair field. Some are not and still have valuable advise.
Then there are the ones who give bad advise, I will call those out.
""Let's also understand that this is NOT about post counts. Post Counts only indicate one's participation, and they mean ZERO otherwise. Content is of much more importance. ""
OMG really? The king of useless posts for post counts and you make a statement such as this????? Most of what you post equals ZERO...............Your content is useless as it does not speak to or give product specific answers. Only generalities which almost anyone could do.
""There is absolutely no need to be childish, to brag""
................OMG really............ what was it you posted in another thread? "Go to my Amazon write up and read my review of...."""
Was this not bragging? I guess because you did a review of a winterizing kit that is it! The absolute truth and that's that! We should be so fortunate!
