southafricanamerican
I am now to this site, but have been reading a lot about this issue and have formulated a plan of attack to fix the issue based on what I have read, but would like some advice on the plan o see if I have the right idea.
First the issue- I have taken the boat out a few times the last couple of weeks after buying it from an older gentleman close by who had the boat maintained by the local dealer/marina. He did all required maintenance and provided paperwork from dealer in support of this. After water testing, speaking to the dealer I decided to buy our first boat. Fresh water boat, dry docked its entire life.
Since then have taken the boat out 3 times and have run into the following issue- trip 1) at idle speeds or anything under 1200 rpm either lunching, docking or cruising wake zones the motor has little to no water coming out of the pee hole, when this happens I get the high temp- constant beep alarm, motor the shuts down. I can restart and go, once over 1200 rpm I get a pee stream, although weak, no alarm. I am able to run the boat for a couple hours with reasonable pee steam entire time, but not what I expected. Get home decide to flush the motor using the fush port and see what happens. Water pours out everywhere except pee hole. I pull off the cowling and find a couple dirt dobber nests I had not seen when I water tested. Clean those out, use a piper cleaner on pee hole and water comes out. Flush another 10 minutes.
Trip 2, starts of great, no issues idling, decent pee (not great). Fun day on the lake, no alarms. Get back to dock, no pee, high temp alarm motor shuts down. Takes all my patience to get the boat loaded onto the trailer. Get home, start flush from the flush port, again no pee stream. I inspect pee hol andit look really tight, so I get a small drill bit an twist it a couple times(by hand) to bore open the hole a bit t provide more flow. This works, get decent stream, but not great. Inspect filter plates and find them clean but installed on wrong sides. Remove continue flush. Install filter plates (correctly).
Trip 3: same as trip 2, except pee stream started better an was very good at high speeds.
Conclusion- I have a block somewhere and possibly a issue with the impeller
Plan: 1) replace impeller (I will probably do whole water pump while im at it). 2) Check t-stats an reverse flush. I will install new ones t be sure. 3) replace water line to the pee hole and check pee he nipple on engine block.
Is there anything else you would recommend I do or try in addition to what i have outlined above? Thank you in advance for your advice
