sandkicker
Outstanding Contributor
"For several years, now, I"
"For several years, now, I"ve been disconnecting the fuel line and letting the engine (BF75-4 stroke) run dry when I'm done using it. The engine will often sit for several weeks unused ( much to my annoyance). I took my wife out on the boat (22 ft Bristol sail boat) the other day and had problem with the engine running. In the end, we never got to sail, we just motored out, had problems and once I got the engine re started just returned to the marina. As usual, I let the engine run dry with the fuel hose disconnected.
This time, I had a flash of inspiration and wondered exactly how dry the carb got to be with the running. I reached under the carb and opened the petcock and rather a bit more fuel ran out than I expected. While the fuel itself was clear, the first bit of the flow was a very dark tea color.
Sooooo... if you leave your motor unused for long periods of time, drain the carb with the petcock... and use a can to collect the excess fuel... DON'T let it run into the water."
