"I am winterizing my 2007 merc
"I am winterizing my 2007 mercruiser 5.0 MPI with Alpha 1 outdrive for the first time. I ran the engine until hot then changed the oil and filter. Opened the single point drain and drained all the water. First off, is this adequate to get all the water out? Then I hooked up a bucket of AF to the outdrive with a short hose and muffs. Started the engine and let it run for maybe 30 seconds and shut it off because it didn't seem to be pulling AF from the bucket and I didn't want to burn up the impeller. I called the yard where I got the boat and they were very reluctant to give me any info but he told me they used a pressurized system to AF the engine because the pump would not pull AF from a bucket like I was trying. Any thoughts on this and should I be using some type of pressure or just add it from above through hoses? Also where this is an MPI engine what is the best way to fog the engine? Thanks in advance for any info and guidance."
