Description of the problem.
Honda bf 25 about 15yrs old.
With the engine warmed up in neutral when shifted into reverse the engine accelerates slowley and tends to bog down. If I decelerate slightly and then accelerate slowley the engine revs up ok to full speed.
With the engine warmed up and in neutral when I shift into forward and a similar thing happens. However, if I decelerate slightly and then slowley accelerate the engine tendes to keep bogging down. If I move the throttle back and forth slowly gradually increasing the revs I can eventually get the motor to get past the he bogging area and then accelerate normally.
The bogging is the main problem but it seems strange that the conditions in reverse and forward are slightly different even though the motor is revolving in the same direction for both conditions.
I have changed 2 of the three carbs in the past.
I have all ways used gas preservatives regular dose or sometimes 2x rated dose in spring.
Lately I changed to Sea Foam brand (2yrs) and use 2x dose first and use regular dose from then on.
The motor is on a sailboat and runs for half hour periods most of the time. Perhaps I may run the motor for two hours+ two or three times a year.
The problem has improved slightly since switching to Sea Foam but only very slightly.
Could the timing be off slightly?
The motor starts every time hot or cold on the first rev even after winter layup and when stalling out after bogging down.
Any ideas ???
Thanks. Nick
Any ideas ???
Thanks. Nick
