fastjeff
Gold Medal Contributor
Old fuel lines on outboards are starting to disentigrate after being exposed to ethanol in the gas. If this happens before your fuel filter it might be okay, but if the deterioration happens AFTER the filter rubber particles will enter the carb (or try to). The result is either a stuck open needle that leaks, or plugged jets. Both can fry a power head, especially those with multiple carbs (since the motor keeps cranking along on the unaffected carbs).
The smart move is to--at a minimum--replace every fuel hose after the filter. Better still, replace them all!
Jeff
Jeff
