Bjsmith919
So I thought I'd figured out why I wasn't getting spark to my port side cylinders but now I'm being told that what I found wouldn't cause that issue. Coil on stator with brown wires coming out is melted, black goo running out everywhere. I have done every ignition test the manual says do, replaced every ignition part except for the stator and rectifier down to the key switch, brand new battery kept on a tender but they all say no. Tell me it's a bad shift switch but was also told V4 don't have shift switches plus I read the shift switch interrupts starboard side not port side. One guy said that if the stator was bad it wouldn't just pick the 2 port cylinders, spark would be erratic on all 4. Another guy told me I screwed up the optical sensor because I installed it outside in the sunlight. Can anyone tell me what's right and what's wrong? I just don't want to throw another $500 at something that's not going to fix my problem.
