98 150hp ficht
oil driver
I have an omc 3 bolt lift ring. It doesn't match up with the flywheel on the 98 150hp ficht, which has 4 bolts that are coarse threaded. What should I use?
No bolts required.-----The lifting lugs are hiding in plain sight.
Well now! I just got to the 98 150 ficht. As usual, your response made me find it. The motor is laying on the ground, which made it a little tricky, but in plain sight is an understatement. Thanks, I found em
