baggedlb7
Ok new to the boating forums and working on outboards. I have built many motors from wheelers to snowmobiles and autos and also inboard motors. A little history my dad has a 98 SeaRay with a 97 carbed 225 offshore and was having issues with it at the end of last season so he asked for help and after some checking a comp check showed number 1 dead and number 2 at 40psi so it has two dead cylinders. After looking at prices on new motors and power heads we have decided to rebuild the motor.
Now for the questions. After alot of reserch I have found not alot of info with these motors but have found multiple different things as far as parts and what is needed and what is not. I have seen some parts places that show one style of pistons for these motors and some parts places that show multiple styles of pistons for these motors and have also read that it depends on what rods it has.
So can anyone shed some light on whats needed for my motor?
What brands of parts are good and what brands should I stay away from?
What hard parts are required to be changed?
If the roller bearings on the crank side rod ends look ok and are smoth do they need to be replaced?
How far can you go on a bore on these motors so far I have only seen pistons in 15 and 30 over?
Once we have it back together is there a recomended breakin procedure?
So far as of last night we have the block off and disasembled and it looks to me that the two bad cylinders have broken rings and the cylinders are pretty messed up. I will be taking the block down to the machine shop tomorrow to see if it is useable.
SER# 06486696
Thanks for any info and replys.
SER# 06486696
