| A friend asked me to look at his '97 200hp Johnson Ocean Runner. It has been sitting for 2 years. Last time he took it out he went fishing. He stopped at a few spots but on the last it would not start back up, it just cranked. 2 years later I removed the plugs and squirted some oil in the cylinders because it hadn't moved in 2 years. It turned over by hand easily without plugs. I removed the fuel line an oil came out. Pumped the bulb till gass ran clear. Removed the carb bowl screws and drained out oil. Pumped the bulb till gas ran out. Put new plugs in, installed a new battery, and cranked it over. Sprayed some starting fluid and it caught for a second. Did it a few more times and the motor started and seemed to run fine. Took it out and when the tach hit about 4000 got a steady alarm and the check engine light came on. The alarm went off and when I pulled the power back to below 3000 so did the check engine light. If I push it back to between 4000 and 5000 it goes on again. I noticed the amp gauge shows 16 volts when the rpm is over about 2000 rpm. I'm guessing that could be a bad voltage regulator. Anybody know how to test it? I have heard that the check engine light is related to fuel pressure. Does anybody have any experience with this? could it also be caused by the voltage regulator? The tach has also started jumping around when at cruise RPM. Again I suspect the voltage regulator is causing it. I don't want to burn up a new battery by running it with too high voltage. After sitting 2 years the engine seems to run pretty smoothly. I had worried about the carbs being varnished up but maybe they are not as susceptible as the 50-60 hp Yamaha 4 strokes I am used to. Any thoughts? Thanks for any feedback- |
