Cable Mariner
I have a 1997 200 HP Ocean Runner that is exhibiting a vibration problem that only occurs in forward gear up to about 2000-2200 RPM. It is obnoxious enough to actually make items near the transom rattle. The vibration goes away when the engine is running at speed, or at least it is not noticable.
I have drained the gear oil and there was no water and the only metal I could find was the usual powdery filaments on the plug magnets. No shavings just powder that feels like grease between the fingers. I bought clamp on dial indicator and check to see if the shaft was bent. There is a noticeable slop in the fore and aft direction which I understand at least to some extent should be normal as the shaft moves from contacting the fore and aft thrust bearings. there is also a small amount of axial play when grabbing the propeller and moving side to side. One final item is that the ****ing into foreward gear clunks much more so thatn my previous motor a 99 150 Ocean Pro which I think used the same lower unit.
I've got plenty of experience with engine work But I have never had a lower unit with problems. I'm trying to figure this out. The only thing that seems to make sense would be the ahead thrust bearing or possibly the ahead gear. Does anyone have any insight into this? I'm guessing that I am eventually looking at a lower unit teardown and inspection in my future.
