Hey guys, i recently starting working on my dads 95 Honda 2hp 4-stroke that had been sitting around for a while and wouldn't start. I thought it was most likely the carburetor so I took it about and replaced the corroded float reservoir. I put it back together and tried to test it out in a trash can full of water. I added a bottle of oil because no oil was showing in the sight window. After that I started it up and it worked and sounded fine. I began to open up the throttle to test it at higher rpm's. I then noticed that all of a sudden a golden colored oil like substance began spewing out from up and under the case. I shut off the engine and felt the liquid. It had the viscosity of oil but smelled strong like gasoline. So I broke it down again thinking there might be a crack in the metal housing of the engine. I then found that there was actually a rubber tube coming out of the metal housing that was the source of this spewing liquid at higher rpm's. I also noticed that their is no water coming out of the pee hole either. Can anyone shed some light on what this tube is and what that liquid might be. Thanks guys, im stuck.
