93 Evinrude 200 Wont Rev Past 3000 RPMS
Amazing. 3 of the magnets under the flywheel came loose and were crammed together on one side of the flywheel next to a magnet that held its ground. never seen that before.
However, that problem (loose magnets) is a common problem, even back in the early 80's.
When epoxying them back in place, use the small 3/8" OD rubber fuel tubing to keep them separated properly. Works for me.
They are back in and drying - installed the replacement stator anyway. Will hopefully get to test later this week. Will post what I hope to be happy results.
Hey Joe - quick question. Does your full advance timing method work on these engines as well? Or does that only work on the older engines? Considering everything going on I thought it prudent to check after putting it back together. Thanks again
The timing system I came up with pertains to the Magneto Capacitance Discharge ignition system...... Timing sensors, magnets, powerpacks, self contained ignition.
Not for the optical ignition setup
I thought so - thanks. But I don’t think I have the optical set up - I think that started in 94-95? Either way, I didn’t think it would work. But worth checking.
Heres a flywheel pic as well from when it was taken off. - I also have a new power pack arriving tomorrow I’ll install if the issue isn’t solved with the magnets and stator. If all is well I’ll send it back 40AC3103-2D44-4321-A4E0-6AEFB4620D2E.jpg
I’ll prepare for the flaming on this but... it works!
i had to do the rev test on land, which I know is a no-no. But it wouldn’t rev past 3400 on land before the flywheel fix - and now it does. Wasn’t able to get to the boat ramp.
For what hat it may be worth I just tapped it up after warm up to see if it would go then brought it down to idle.
Such a a great feeling though.
Thank you everyone for for the help. Hope to water test soon and confirm everything.
Water test done. 5500 RPMs wide open pushing this old mako 228 to 43 MPH and nice 3700 25 mph cruise.
tLDR - check your magnets and bonus points for checking all grounds.
