timguy
Silver Medal Contributor
Need a good tech for this one:
Working on a 1990 90 Evinrude which was rebuilt by a local shop after VRO failure. Tech had installed .030 pistons and circumvented VRO, recommending Amsoil premix 100:1. Guy that bought the rebuilt motor from the shop had it installed by the tech on his boat.....but later had it back several times because of poor running and bad idle. Guy says that he was never satisfied with the way it ran. Note: I see all new electronics from CDI. Guy.......we will call him Joe "boat owner", and Jeff the "tech" finally parted ways. So now Joe finds me 3 years later..........Joe never ran boat much at all........and has me fix the problem. Electronics checked out brilliantly so I checked fuel and filter.....all spotless. Noticed melting at base of power pack........obvious overheating.......even coil bases melted......wow!.......No overheat cut out or buzzer? Apparently not. Joe says always saw water stream. So next I check compression.......50, 90, 85, 90.......yuck! I suspect head gasket because motor had pretty loose head bolts with no dressing on threads or bolt head shoulders. Sure enough, cyl 1 blown into water jacket.......long time running that way with water pitting on top of #1 piston. NO scoring, all cylinder finishes flawless. Top of cylinders slightly blued and straw colored from heat. Very excessive piston clearance........can put a .022 feeler gauge between top of pistons and cylinder walls.
Here is my take: Jeff set up with too much clearance to begin with and then improperly torqued heads. Head gasket began leaking compression into water jacket and disrupted flow of fresh cooling water, "not salt water". As leak got worse, engine began overheating but still showed water out the indicator port. The excessive piston clearance and Amsoil protected engine from major meltdown..........
Okay, questions, whose fault is it and what can we do to fix the motor? At that clearance with overheated rings and 90 psi will this be a serviceable engine? Joe has $3,000 invested in this engine and wonders if he wants me to rebuild it for another $1,000........or try some head gaskets for $200. No comment yet from Jeff. This doesn't include hooking up the overheat protection / warning........Okay, Thanks for your help in advance, Timguy
