I took my gear case off to get to the impeller so I could figure out why I wasn't getting any flow. I think I may have resolved that issue, but somehow I seem to have jammed my gear case.
When I mated the gear case to the lower unit, I lined everything up, and then connected the barrel nut a few turns. Then I bolted the case to the lower unit. When I went to try the shifter at that point, it would not move in either direction. I disassembled everything again at that point and have the gear case in a vise on the workbench. The prop turns freely, but it spins the drive shaft. I tried pushing and pulling on the shift rod that extends out of the gear case and it does not budge.
At that point, I called it a night. All I can figure is that when I tightened the bolts to reconnect the gear case to the engine, it put excessive down force on the rod and caused it to jam something inside the gear case.
Hopefully someone has seen this before and figured out a solution cheaper than replacing the entire gearcase assembly.
TIA,
JPK
TIA,
JPK
