reefrunnerau
"More problems!!! Was running
"More problems!!! Was running a bit warmer than usual so had to keep the revs down a touch, at the end of the day the oil pressure was down to nearly failure at idle and about 25psi at revs. At cold the pressure is nearly normal. Thought it might of been bearing problems but oil anaysis is normal. Any suggestions as to what it might be???? Thanks."
