Nathan Kramer
Alright guys hoping you can help a guy out here. Bought an 89 Ebtide 18ft. with a Merc 150 HP black max outboard. Boat was on consignment at the local dealer nice guys and they did their dues and had went through the motor before selling it so it was good. We took it out an ran it through its paces ran good and hit 47mph(GPS) with max capacity of 750 lbs in the boat.
So here i am two months later and i have a few problems. Biggest being the battery is not charging. Dealer put a fresh battery in before i bought it because it had been setting for 6 years in a garage. He drained everything and changed fuel and fluids just for piece of mind. It seemed a little cold blooded last weekend starting since it hadn't been started in a few weeks. Didn't pay no mind to that as i was told their cold blooded. Ran good for the most part but slightly different in sound. I am new to boating as an adult and operating one. I was however a Navy electrician and have been working on motors since high school but these outboards are a little different animals. Friday rolls around and i forgot to prime the fuel so it cranked over four times before i realized what the issue was. So i corrected that and it started cranking slow. battery was low. So I got a new deep cycle for the future trolling motor; jumped it off that battery. It started and ran fine. Went to the fishing spot shut it down, and few hours passed and went to leave the battery was dead. Granted we weren't underway a long time but i would have thought running a few miles up river would have charged the battery up a little. So swapped the batteries and the motor started fine with the fresh battery.
I am thinking its the voltage regulator or the stator. Called the boat dealer he was kind enough to tell me where to check with my meter to see if i am getting good voltage into the voltage regulator. He said on the two yellow wires coming off the stator i should get 180 to 200 volts peak. Is this at idle or at X value RPM? At idle at the ramp i was getting 7 VAC to phase to ground. Phase to phase 10 VAC. Is that normal or am I checking it wrong? I was also looking at prices and i see the Voltage regulator is 600 plus through the dealer and the stator was 500 pus. If there is something else i need to check i can do that too.
Any help would be awesome. Single dad just trying to take his son fishing safely.
Thanks in advance.
P.S. at 5500 RPM with just me in the boat i was only running 46 mph with calm water.
Thanks in advance.
