Normal timing on my Johnson 200 at idle per the manual says it should fire at 6 degrees ATDC after quickstart is disengaged. Quickstart is supposed to advance timing to roughly TDC (or 1 inch on the flywheel per the manual). When performing the functional check of quickstart and I'm holding the timing light at the flywheel, I can visually see cylinder #1 firing at both locations on the flywheel as if it is "mixing" the firing for idle. It is doing this on all cylinders, on the muffs and in the lake (I indexed all cylinders TDC on the flywheel). The Powerpack is a new Sierra, so I called them up for a professional opinion. The guy on the phone says that it is a mixed firing. Has anyone else noticed this?
