As I know the system on this boat is not designed to charge the battery per se, however maintaining the voltage is still an issue reguardless. It all started July 2014, was out on the lake cruising and I happen to see the needle spiked out on the volt gauge. If I could guess, 17-18 volts. Pulled the engine cover and the coil windings we pretty hot, most likely the cause of the shiny gooey stuff on the top of engine. Since than I have replaced the stator and regulator/rectifier. Now it's been a year or two and every 2-6 months the voltage gets out of hand again. The new parts are aftermarket CDI components. I am currently working on sending the regulator/rectifier back for warranty again for like the 3rd or 4th time. The sketchiness of the charging system has led me to install a quick disconnect for the yellow stator wires, so I can do it on the fly. Now I have contacted Marineengine.com to possibly return the CDI for an OEM regulator/rectifier. Hopefully this will take care of my problem. I have checked so much on this engine that I'm looking for some help. I have a Exide Stowaway 27 dual purpose marine battery, no wing nuts anywhere. Checked grounds and all other connections. I was interested in how much power my boat actually consumes and if everything is on including live well pump and bilge pump with fish finder and FM radio blasting and it maybe hit 3 amps. Without the bilge and live well on its about 1.5 amps. I have checked output of amps from the boats charger right at the engine and have never seen more than 7 amps out of that thing. Even when the volts were getting out of hand, the amps seemed to stay at 5 - 20% capacity. I read another forum talking trash about CDI's regulator and describing the same issue I'm having except the post never had an ending. The guy never came back and said, screw it I'm just going to not have a charger, like I soon will...
