I got a 1986 85hp force 3 cylinder outboard. Right now the boat doesn’t get to full speed of 32 mph. It goes about 5 mph. Last year it had a similar issue with cylinder #3 and a rectifier fixed it. This year not so much. I’ve switched the ignition packs and the problem remains on cylinder 1. I’ve resistance checked the stator, triggers and they seem good resistance wise. I used a tachometer and spark tester and have spark on all 3 cylinders. Cylinders 2&3 had 22 volts going to them and #1 had only 4 volts on the spark plug wire. My next test is to switch the ignition control modules as the one is only using half for the third cylinder at the moment. With that I’ll have to switch the trigger and stator wires to maintain the timing. Any other suggestions would be greatly appreciated. Thank you.
I forgot to add that currently the idle is screwed most the way out to enable shifting gears, or the rpm’s would be too low to maintain the engine while shifting gears.
