85 HP Force 1985 (856F5A)
cdjr
Hi all,
I've been fighting this motor all summer long trying to get it to full power. A friend (haha) worked on it and adjusted the linkages to who knows what. I decided to do a link and sync and check the timing, lo and behold, the number one coil is not firing. I switched the number one with number two and it fires so I have determined that it is the coil. My question is: Is there any issue purchasing the CDI versus the Mercury? Quite a bit of difference in price.
Thanks in advance
Standard Magneto, cheaper than the rest.
Standard Magneto Sales Company, Inc.
212 Ash Ave., Wood Dale, Illinois 60191
Phone 1-800-MAGNETO
(1-800-624-6386)
Blue Ignition Coil 5-5170 (FCB 3020E)
Fits On Force Motors
Phone 1-800-MAGNETO
(1-800-624-6386)
Thanks Jerry, I'll give them a call Tuesday morning. I did see them for $77 on Amazon
I was looking at the website. If those prices are correct, I'll buy all three!. Do you happen to know if they sell the spark plug boots also? I'll have to get them too. Thanks again
They went up in price a little but I bought three of them. Don't know if it's overkill but I figured I would play it safe. Do you happen to know the diameter of the spark plug wire? I forgot to ask when I called them and I probably need that to buy the boots.
Not sure of the size.
When you get them, take em to Auto Zone or Napa.
Just remember to get the ones that don't come loose easy.
Called today to follow up. They are out of stock and will not have them for at least a couple of months. Guess I'll order one from Amazon.
Got the coil from Amazon. Put it on and I still do not get spark to number 1. Now I have to think the CD Module is bad. Any way to check? I suppose I could swap out the wiring to see if that does anything. Not ready to spend close to $500 for a new one if that is not the issue.
If you have a trigger signal to the cdi and nothing coming to the coil, you have a bad cdi
im going through a very similar issuse i started 5 years ago and gave up im starting back up trying to fix it, i think you have to just check resistances from the trigger
OK, before I blow the whole motor up swapping the packs, it looks like all I would have to do is change the quick disconnects. It looks like there are 2 on each side of the motor. I have pictures but cannot figure out how to post them yet. Says they are too large
Ok, Just had to resize them.
Well, the nice weather has ended with no change in sight. Pulled the boat out of the water, winterized it and just have to cover it for the winter. All plans are now on hold till spring. I think it may be the pack. I'll revisit in the spring.
Happy summer everybody!!
Finally got back working on the motor. Haven't done a thing to it other than put fresh gas and a fully charged battery in it. Starts right up, but I am not getting spark on number 1 AND number 3.
I'm beginning to wonder if this motor is heavy enough to sink to the bottom of one of the Great Lakes???? (LOL)
I'm half tempted to just buy two new packs and coil.
Any thoughts before I start sinking more money into this motor?
Thanks in advance
Confusing: starts right up but no fire on 1 and 3???
Most 4 cylinder Forces won't start on just 2 plugs.
How are you testing the spark?
No spark on the first half of both packs usually goes to the stator.
outboardignition.com has test procedures for your ignition system.
You will need a DVA or Peak Reading Volt Meter to test the right way.
First thing I'd try(no meter) is swap the packs around and see if the spark is
still gone???
It's a 3 cylinder. Testing the spark with a cheap HF spark tester and a timing light. I will swap the packs first to see what happens. Asking around to my friends to see if anyone has a DVA . No luck so far. I may have to either buy one or build one. From what I see it shouldn't be too difficult, just have to figure out where to get the parts. I'll let you know
A 3 cyl. and no spark on 2.
Then it's absolutely amazing that it runs at all????
If you have a regular Analog (sweep) Meter you can test the stator with it.
The DVA is for the more complicated tests.
Tested the stator. Resistance from blue to yellow wires (2 places) both check right around 350 ohms (where it should be). Blue to ground and yellow to ground (2 places) all check right around 90 ohms (should be an open circuit).
Have not been able to swap packs, should be able to try that tomorrow.
PS: Happy belated birthday Jerryjerry05. I'm right behind you.
