Have replaced many over the years for this problem and Merc service school could not tell us why other than it was a feedback thru sensor. Also see below from CDI troubleshooting as it on the last paragraph.....If the trigger was bad the engine wouldn't run or produce the spark we are getting.
http://www.youtube.com/watch?v=Hw4QvI6k0SU
If that isn't a running engine, im not sure what is. Yes the battery is somewhat dead, thats why theres such a hard start. Me and my partner have checked every system on the engine. If the trigger was bad the engine wouldn't run or produce the spark we are getting. The compression is good down all six cylinders. The fuel is good. We have also resistance tested every component that we could and it all checks out. We can't find anything that would point to not allowing the engine to continue running after it has started. And yes I do have continuity on my ignition switch when it is at run. If there's anything else I could have missed or am overlooking lemme know so I can check
Post the serial Nr. so we can help.I have the same problem also,can not figure it out
Just got mine solved it was the trigerHello, did this issue get resolved? I have the same problem and would like to know what the problem is. Thank you
