8.1 overheated - aborted trip. I broke down for the first time ever yesterday and came back to port on one engine because my Stb engine overheated.
I was about 25 miles into a 70 mile trip and cruising along nicely. All of a sudden, the RPM’s dropped and my exhaust hose temp and engine alarms went off. I stopped, opened the hatch and coolant was spraying out of the coolant recovery tank vent hole. The temp shot up to 250 after running at 175/180.
My first thought was RWP. No big deal, I have a spare pump and impeller onboard but the raw water flow was fine. I popped the cover off of the RWP just to make sure all of the vanes were there. I thought (wishful thinking) that maybe a bag got caught on the intake and caused the overheat but after cooling down and running again, the temp started going up right away. I replaced the thermostat and circulating pump when I went through both engines two years ago. The heat exchanger was rodded out at the same time.
This was a pretty quick spike in temperature so I feel like something failed. It was running at 175/180 minutes before this happened. The thermostat seems unlikely since temps were good already run for over an hour. I only replaced it because I had the engine home and was replacing the short hose proactively. Ironically, I didn’t do the same on the port engine. I have about 70 hours on the new thermo and circulating pump. (AC Delco).
The circulating pump seems like a suspect only because of how quickly the temp jumped. I removed the belt and it feels fine when I rotate it. Has anyone ever had the shaft break internally? Meaning the bearings are fine but the impeller isn’t moving any coolant. What’s the easiest way to rule that in or out?
Coolant level was good in the h/e, I checked that yesterday after it cooled down.
What else should I be checking? The oil is clean and at the right level.
Bob
Bob
