79 Mercury 150hp V6 I am having problems with the electric choke when I press the choke button the butterflies close as suppose to but when I turn key in the start position and hold choke button the choke opens when cranking then closes again after starter is not engaged anymore.. can someone help me in why the choke does this as its not helping start the engine with choke button is used.I have to use starting fluid to start and hold the choke button for a few seconds until warmed up as it works only if starter isn't engaged ..
